hey guys,
just got my 95 gtr, and i love this thing, i have a few thousand set aside for upgrades,
i need some help here,
was thinking of starting with some pod filters and a apexi computer, already has an existing cat back exhaust
suggestions?? sorry i am new to this
thanks guys any help would be very much appreciated.
https://www.sau.com.au/forums/topic/387114-just-purchased-my-gtr-and-modding/
Hi Mate welcome what mods if any are on the car at the moment? And what are your intentions with it.. As in Will you be using it as Just a daily driver, or a daily With some light track work Every now and then, or lots of track work etc etc?? But assuming its Stock and going to be driven daily i would invest in a good panel filter for airbox like a K&N or something, buy some decent shocks and springs, get a good set of brake pads and fluid, buy after market dumps, front pipe and exhaust get an electronic boost controller and invest in a power fc, nistune, vipec basically something that you can get it tuned and the boost slightly raised should be happy a d entertained for awhile.. :D but at the end of the day matey its your car you should do what ever makes you happy :-)
Throw some pics up :) Cheers sime
Welcome mate!!
Apexi, boost controller, exhaust from turbo back, adjustable cam gears and a tune should net you some healthy gains
Personally I would say stay with stock airbox it's good for alot of power and won't get defected
Have a look at the rb26 dyno thread for some ideas and the definitive guide to a 300kw gtr thread in forced induction page heaps of info and ideas for you there
Most importantly enjoy it!!!
