Nissan Skyline GTS-t 4 Door 1996 Series II (white). Only quality mods. Makes 243 rwKw. Suit somone after a Sleeper or Drift Car.
Spec Lists:
Engine:
-RB25DET (tuned by Rich at Rising Sun Performance; a highly regarded UK import tuner)
-Blitz SUS air filter and Blitz inlet pipe
-Greddy 3" down pipe
-5Zigen Fireball exhaust system
-Greddy TD05 RB25 turbo kit (fully rebuilt only 1,500 klm’s ago) with S/S braided oil and water lines
-Blitz LS front mount intercooler
-Blitz Blow off valve and factory pipe
-19 Row Oil cooler with speedflow fittings and Greddy thermostatic 4 way take off plate (-10JIC)
-Greddy Oil catch can
-HKS 740cc injectors
-Nismo Fuel Pressure Regulator
-Z32 Air Flow Meter
-Apexi Power FC with hand controller
-Blitz Dual SBC Spec-R Boost Controller
Drivetrain / Brakes:
-KAAZ 2-Way LSD (brand new)
-Exeedy Heavy Duty Sport Clutch
-Full R33 GTR Brembo brake conversion (front and rear) with HEL s/steel brake lines
-GTR EBC grooved front disks with red stuff pads
Suspension/Chassis:
-Kazama Castor Rods (new and unfitted)
-Cusco type OS Front Strut Brace
-Nismo Rear Strut Brace
-HSD/Dritworks 'CS2' fully adjustable coil overs
-HICAS lock out bar
Interior:
-Razo Race Pedals
-Razo Shift Knob
-Alpine H/U with 6" speakers all round with tweeters (+ wired for sub)
-3x Defi BF Link meters 60mm, with genuine visors (Boost, Oil pressure, Oil Temp)
-Defi control unit 2
-Defi 115mm Tacho with shift light
-350mm Sparco suede steering wheel with Quick Release hub and genuine Nismo Boss kit
-Turbo timer
-PLX Devices AFR unit and 52mm gauge in Defi cup and stand
-Cobra alarm & immob.
-Nismo Key and spare
-Battery relocation parts installed in boot.
Exterior:
-17 inch Super Advan tri spoke two-piece alloys
-Hankook Ventus 255's on rear and 235's on front
-Nismo from bumper with '2 door' indicator light conversion
-D-Max Carbon Fiber GT wing (curently off the car)
-Rear Pods (un-fitted)
-Side Skirts (un-fitted)
-Tinted Rear Glass
-Original paint in good condition for its age
Dyno sheets available upon request. Makes 243 rwKw at 1.1bar Boost. This is a quality "street sleeper" or quickly converted into a competitive drift car. Only quality Jap parts used in this build. Only selling because I have moved to Singapore for work. $17,000 ono
Cheers, Anthony +65 9127 2512 (txt me and I will call you back). In Australia for holidays till 22 Jan 2012...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
