Varrstoen 2.2.1 in 18x10.5 +15 aggressive fit for GTR - BRAND NEW in boxes $1100
post-3189-0-86723900-1325930043_thumb.jpgpost-3189-0-95065300-1325930074_thumb.jpgpost-3189-0-72615800-1325930239_thumb.jpg
Enkei Rpo1 17x9 +15 17 x 9 Enkei 5 spoke wheels - including 6 255/40R17 tyres (4 on the wheels). 2 x tyres Maxxis @ 20% worn, 2 x Bridgestone runflats at 40% worn, 2 x Maxxis @ 80% worn (tyres not on rims). <br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">$800ono<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">post-3189-0-30878100-1325930374_thumb.jpgpost-3189-0-67836200-1325930397_thumb.jpg<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">One rim has a hairline crack on the inside of the rim on the very outer edge of the lip - been quoted $200 to fix.
Work Wheel nuts x 16 brand new. Will throw in 4 x lock nuts WITHOUT key for free. Locknuts have had some extra lovin' with an extra FBH and socket....but that's another story. $100 plus post.
Swirl Pot / External Fuel Pump setup. Some fittings still attached - previously housed a single 044 and was fitted to R32 GTR. Get your beast prep'd for the SAU:SA track day and eliminate fuel surge! Fitting available. $250
Previous setup:
Pickup Adelaide or for the bigger items organise your own postage. Happy to drop at a courier depot.
Cheers,
Andrew
Edited by Blue32
what happen to the fuel lines and pump? is that your best price?
Fuel lines and pump used in dual 044 setup I now run with E85. There is a little room to move on price thumbsup.gif
$750 ono
Work Wheel nuts x 16 brand new. Will throw in 4 x lock nuts WITHOUT key for free. Locknuts have had some extra lovin' with an extra FBH and socket....but that's another story. $100 INCLUDING post.
Swirl Pot / External Fuel Pump setup. Some fittings still attached - previously housed a single 044 and was fitted to R32 GTR. Get your beast prep'd for the SAU track day and eliminate fuel surge! Fitting available. $200
PRICE DROP
Edited by Blue32
Hey, I'm interested in the Enkei's, but without tyres. How much for runs only?
How straight are the rims? Thanks Brad 0416320930
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
