hey all. selling my ca18det and gearbox
engine is in a few bits. head, with everything on it including turbo and loom and ecu.. and block with crank and three pistons. one was stuffed but the bores are all good.. chuck me a price if ur interested :)
also after rb20 power steering bracket, AFM and rb30 engine mounts
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
