ITEM: GTR Trust/GReddy Drag Intercooler 710x165x305mm with single 80mm inlet & 100mm outlet end tanks with a polished finish
***Trust/Greddy don't actually make a single entry end tank for this core (only twin entry), so I had a 150mm wide Trust cast end tank widened and welded on
CONDITION: AS NEW & UNUSED
PRICE: Worth over $3,000 new - selling for $2,500
PAYMENT: Cash on pick up or direct deposit - postage extra
CONTACT: In here or via PM
OTHER: This is the biggest and baddest GTR cooler around. As seen on many huge HP GTR's.
NO TIMEWASTERS OR LOWBALLERS.
Pics soon.
  • 4 weeks later...
As per the first post, location is in Sydney (Western Suburbs).
PM me with our number and I will call you (if you are serious).
Shah, email going your way shortly with shipping quote.
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
