Has anyone here bought a cooling pro rad from just jap? how good are they? going to buy one for my 34 turbo but hearing from some that they tend to leak. Just wanting to know people with skylines input on this.
https://www.sau.com.au/forums/topic/388834-just-japs-cooling-pro-radiators/
Had one in the 32GTR, mate had one in his 180sx and still using it for the v8 that is in it now...
They were/are good for the price. The only issue I have seen is that the early one's years ago had crappy filler necks and tended to leak. They fixed that pretty quick after that.
So thumbs up from me...
The water temp sensor bung in the bottom of the radiator isn't the best fitting, using a normal o-ring gasket mine still leaked so I had to use gasket maker to get a seal.
Also, on R33 the top tank doesn't have a cutout (it's too high on the passenger side) so if you are running standard airbox the intake duct won't fit properly. Not an issue if you're using a pod filter I guess.
They're cheap radiators but they do the job. Fenix make radiators with the correct relief on the top side if you have an R33. Haven't looked at the R34 model.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
