Has anyone here bought a cooling pro rad from just jap? how good are they? going to buy one for my 34 turbo but hearing from some that they tend to leak. Just wanting to know people with skylines input on this.
https://www.sau.com.au/forums/topic/388834-just-japs-cooling-pro-radiators/
Had one in the 32GTR, mate had one in his 180sx and still using it for the v8 that is in it now...
They were/are good for the price. The only issue I have seen is that the early one's years ago had crappy filler necks and tended to leak. They fixed that pretty quick after that.
So thumbs up from me...
The water temp sensor bung in the bottom of the radiator isn't the best fitting, using a normal o-ring gasket mine still leaked so I had to use gasket maker to get a seal.
Also, on R33 the top tank doesn't have a cutout (it's too high on the passenger side) so if you are running standard airbox the intake duct won't fit properly. Not an issue if you're using a pod filter I guess.
They're cheap radiators but they do the job. Fenix make radiators with the correct relief on the top side if you have an R33. Haven't looked at the R34 model.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
