94/95 black 117,000km full 100,000 service completed
Full M spec kit
Air bag
Series 2 rear spoiler
Sunroof
Blitz electronic boost controller
Front mount intercooler
18" wheel
Dual gauges with holder boost and air fuel ratio
Hks turbo timer
CD/SUB/AMP/SPLITS
Bulstein height adjustable coil overs
Apexi air filter
Apexi dual chamber bov
Full 3" exhaust system
New clutch
contact 0405 539 114
Price $19500.00
EMAIL ME DIRECT FOR PICS
https://www.sau.com.au/forums/topic/38894-fs-9495-gts-t/
sorry dude dont have pics of the interior
its standard inside steering wheel with air bag,
turbo timer and boost controller located near the drivers knee,
there is no noticable scratches on the panels and there is no marks on the seats the tweeters are mounted flush in the door.
if ya really interested then give me a buzz and are in sydney????
https://www.sau.com.au/forums/topic/38894-fs-9495-gts-t/#findComment-827783
Sounds like a nice car.
I regret letting my R33 go.
But, not wanting to doubt you but you quote you have 201kw at the wheels on 12psi.
Have you got a dyno sheet to back it up or any secrets as to how you got it as you only have very limited mods plus standard computer and standard turbo.
I had a APEXi Power FC, HKS front mount, HKS Filter, HKS BOV, HKS turbo back exhaust, high flow turbo and 16psi and still only managed 194kw at the wheels.
200kws at the wheels of a R33 is hard to get.
Not doubting you, just impressed, i love Skylines.
https://www.sau.com.au/forums/topic/38894-fs-9495-gts-t/#findComment-840214
metro rego is due in late this yr NOV maybe around that time it think,
and the sound set up is kenwood deck and splits is pioneer bullets, with kicker 4 channel amp with sony subs in box and stock rear spkrs not a big sound freak just clear
Mr Rb20: yeh buddy i do have the dyno sheets to back it up and u can go to the www.silviansw.com and check my result with mods from the dyno day... no secrets here there the performance mods it has stock turbo not a full exhuast standard dump pipe, and standard ecu all work and mods eg cooler and filter was all done is sydney. The servicing is done by myself as i dont like giving my car to others. send me ya email i will send ya my dyno result.
https://www.sau.com.au/forums/topic/38894-fs-9495-gts-t/#findComment-840525
hey dude the dyno sheet is on my site now u can view it.
https://www.sau.com.au/forums/topic/38894-fs-9495-gts-t/#findComment-847812
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
