Ok guys finally for motivated and welded the holes in the boot of the 32 and now I need to do my gtr are Bonnet
These are my options and I'll explain why
Option one is to tig the holes up before anyone says anything yes I'm a qualified sheety and I know how to weld ally
The only thing is I've never welded any that thin it looks to be about .7mm thick and for any one that knows ally knows that at the rate that ally heats up it won't take much to warp the shit outta my bonnet
Now my idea is to put a backing plate behind the holes and to get a nicer finish on the inside
I also am thinking of getting some preety solid Dolly's an brass blocks to put around the weld area to soak some of the heat due to the tig welding and te amount of heat i will putting in there hopefully aiding in preventing distortion .
Any one welded one before or the Same thickness or thinner material ?
Other option is to sikaflex a plate on the isinde and fill them with filler but Is a lil dodgey
Any help appreciated
Cheers
Bejay
Tried to repair a few GTR bonnets and I can tell you don't even bother trying.
The material they used is rubbish to weld,
If you've ever tried to weld a recycled alloy street sign a GTR bonnet is verging on the same material.
  • 1 month later...
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
