Hi guys,
Have an R33 S2 steering wheel for sale, it's in very very very good condition with hardly any scratches. I bought this to replace the worn out steering wheel in my r33, but I never got around to changing it and I ended up selling the car.
$120 pick up from Mernda (outer north-east suburbs of Melbourne) or Thornbury (inner northern suburbs of melb). This is substantially less than I payed for it!
Any questions, feel free to ask : )
Adam.
https://www.sau.com.au/forums/topic/389801-s2-r33-steering-wheel/
I'm not 100 per cent sure mate, i'm pretty sure it's the same steering wheel as the s14, but it might be worthwhile checking compatibility.
No, will not fit Silvias. Places to screw the airbag components in are different as a mate of mine tried to do this to his S15 with no luck.
There ya go guys, it's official, this is a skyline wheel only!
I've received a bunch of messages from people asking me what makes and models this steering wheel will fit on. The short answer is; I have no idea. I'm not a mechanic, and I wouldn't have a clue. As far as i'm aware, this steering wheel will fit r33 s2 gts-t and that's all! If you want to know if this steering wheel will fit on your 180sx / GTR/ hovercraft, do some research and find out, because I can't tell you!
Sorry to sound like a complete kunt, but the messages i've received are ridiculous!
