cheers so far. ill wait till 12people respond then have to get email addys from the people so i can create team and send out invitations to the players. i found last year that if you don't get full teams of friends you end up with DR dream team and other organisers competing directly against you which isn't fun
matt
  • 3 weeks later...
  • 3 weeks later...
http://www.facebook.com/l.php?u=http%3A%2F%2Fdreamteam.afl.com.au%2Finvite%2F645868&h=dAQHL_SY-AQGLtQ5roXXicXQHTtTw4xj0BLOfjtyZX6NfmA
just click on the link. we need more people, its just a bit of fun and doesnt takr long each week:)
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
