Because the CIA, who placed a tracking bug in my head, need to get the data out of the chip, and it only transmits on the same frequency that the marshals use and is triggered by the combination of thick white smoke produced from drag cars and loud car noises.
Awwww cool, but I think it only be fair that you wait until someone else posts cool story :D I was hoping that this thread would be great amount of fun, looks like I'm the only one with a little thing called an imagination ;)
I have chronic diarrhoea and my doctor said that the only cure is to go to the drags and inhale as much white tyre smoke as I possibly can, then if that car wins, my illness will disappear with three puffs of white smoke out my ass.
Yeah ok, you got me...
I really need to go because I have never smoked in my life and the aliens keep abducting me for experimentation on my lungs because they are so pure. I am not keen on smoking to hopefully by going to the drags more frequently I can take on the fascade of having less than healthy lungs in the vain attempt to stem the occurance of anal probing...
Because the east African tribal fish are relying on me, their team leader, to bring back some shredded rubber & white tyre smoke in order to cure their incurable and insatiable obsession with south American skydiving donkeys. This can only take place if I kiss the holy grail of Willowbank-Raceway.
Hows this:
I must inform the participants that the parachutes which are being used come second hand from those used on the space shuttle and might burnt up if deployed at a wrong angle which flabbergasts me at this floccinaucinihilipilification and must take this information to the meeting organisers during the meet!
OH YEAH Triple word score for proper use of floccinaucinihilipilification!
Yes it is a word :D Yes I can say it out aloud :)
http://www.quinion.com/words/weirdwords/ww-flo2.htm
FLOCCINAUCINIHILIPILIFICATION
The action or habit of judging something to be worthless.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
