Things have changed and its now time to sell the toys and buy a house :(. I bought the car around 18 months ago with the intensions of driving it on the weekend and using it for time attack. Since buying it I've driving it around 5 times one including the drive to Mallala with the SAU:SA track day where the car performed very well.
*SUSPENSION + BRAKES + ETC*:
R33 gtst front brakes (redrilled to 4 stud)
QFM A1rm fronts pads
Ebc Black Stuff Rear pads
Cusco 'AS' Front Strut Brace
Cusco 'OS' Rear Strut brace
Cusco Castor Rods
ISC N1 Coilovers with new Thrust bearing kit F8kg & R6kg
R32 GTR rear sway bar
*ENGINE + EXHAUST*:
Redtop SR
HKS GT-SS turbo in t25 housing
850cc injectors
3A racing pod
Hard intake pipe
z32 AFM
3" dump and front pipe
Air diversion panel
Nismo low temp thermostat
Oil cooler and relocation kit
Koyo Radiator with High pressure Cap
NEW Calcium battery
NEW HDI Front mount
NEW Walbro fuel pump
NEW braided turbo lines with inline filter
NEW gfb bleed valve
NEW overflow bottle
Needle Roller Spigot Bearing
-Custom 3" cat back exhaust with flutes
-High flow cat 100 cell?
-One Muffler
New Genuine Nissan:
-water pump
-clutch slave
-clutch master
-Cometic multi layered manifold gasket
-dump pipe gasket
-Manifold to turbo gasket
-New manifold studs
-New exhaust studs
-Nisstune
*EXTERIOR*:
Sun roof
[ ][ ]SILVIA[ ][ ] Head Lamps
Wing-less
Aerial-less
Gtr style Grill
Varrstoen te37 copies 17 x 9 + 12, 17 x 9.5 + 12
Federal 595 with 90% tread
Origin Roof spoiler
*INTERIOR*:
Nardi steering wheel and genuine horn
Greddy copy bucket drivers seat
Superlow seat rail
R32 GTR passenger seat
Digital Climate control
Pioneer head unit
Soundstream Tarantula 6.5" speakers
Auto meter boost, water temp, oil temp and oil pressure gauge
nismo gear knob
*DRIVETRAIN*:
NEW Braded clutch line
Turbo 5 speed box - new oil
Extra H/D single plate clutch
3.9:1 LSD 6 bolt - new oil
The bad: Body has had a respray a few years and but has a couple of marks in the paint (not noticable unless you get close), had some rust around sunroof but was cutout and fixed up.
Located in western suburbs Adelaide
Contact: 0430 362 050
P.M or email - [email protected]
https://www.sau.com.au/forums/topic/391936-silvia-s13-1991-sa/
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
