Hi
R34 GTT isnt getting a signal to the fuel pump
have tested the fuel pump with a direct 12V source and it works
when car is switched to ON, the pump doesn't prime
does anybody know possible reasons for this?
is there a stock fuel pump relay, if so where it it located?
thanks for the help
https://www.sau.com.au/forums/topic/392070-no-signal-to-fuel-pump/
had a similar prob with a sr s13 turned out to be the bolt that holds the ecu plug in was not done up
ecu plug is deffinitly on tight
i tried to get some diagnostic codes using the diagnostic plug, but couldnt get the engine light on the dash to flash
im leaning towards a faulty ecu
gonna try get hold of a spare r34 neo gtt ecu to test it, or put my ecu in another r34 (if anybody can help me that would be great)
cheers
surely there should be a relay in the fuse box under the bonnet in r34 test if there is power getting to the relay if there is its prob the relay if not, its something pre relay ecu/wiring/earth maybe if you wanna check if the ecu fuel pump output is working get a wiring diagrame and check the wire on the plug for ecu?
I just had this issue with my R33.
Hard wire it to another 12v source. I used the 4ws lol. Seeing as im not using it.
In my case it appears the circuit is dodgy. As my boost controller stopped working too.
Fuel Pump, boost controller (wired to stock solenoid wiring) and stock narrowband were all only getting 11v. Not enough to make them work.
I just re wired them all to different sources (bar the narrowband as its not in use) and all is fine again.
Leave the earths as the are.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
