Hi all, am clearing out the garage of some unwanted stuff.
All items are pick-up preferred from Warrnambool Vic. Can post smaller stuff at buyers expense. Can also deliver or meet buyer half way at buyers expense.
PM, post here or text 04 3774 5147 for more information any questions etc.
I am unable to post photos at this time as the camera I have takes 4mb+ photos. I can however MMS photos.
1. Assorted EMPTY tool cases for the following Sidchrome 3/8" and 1/2" socket sets, Repco 1/4" socket set, Stanley screwdriver set, EMPTY spanner rolls for Sidchrome ring-open-end, ring, double-open-end spanner sets.
>>>>ALL CASES ARE EMPTY<<<<<
$20 the lot
2. Nakamachi? CD player, came with car, working condition.
$5
3. Exedy clutch kit, good condition, only removed/replaced due to noisy spigot bush and didn't ant to get caught out. Part number on pressure plate is NSC 534. Came out of R33 GTS.
$50
4. Stock coils. Suit diagnosing dead miss etc. Out of series 1 R33 GTS
$10
5. Stock dump/front pipe suit R33 GTST
$10
6. Stock thermofan, removed to fit FMIC, HAS BEEN MODIFIED
$10
7. Stock Jecs fuel pump from R33 GTS, unknown condition
$5
8. Stock intake/rubber pipe and crossover pipe
$10
9. Genuine Mazda RX8 rotary oil and filter suit RX8
$20
10. Speco Meter oil pressure gauge, think it's 2.5", has sender
$10
11. Stock Mazda RX8 spare wheel, unused, has leather cover
$10
12. Ryobi mitre saw, part number EMS 1221, 1200w, 210mm, braely used, still in box with accessories. Paid $130
$30
13. Stock springs and shocks from R33 GTS
$20 the lot
14. Assorted EMPTY Snap-On tool cases, part numbers CTSA561CL, CTSA561, CTA4850, CDRA6850, suits 1/2" electric rattle gun, cordless drill, cordless bit-driver, and 3/8" rattle gun CASES ARE EMPTY
$20 the lot
15. Stock swaybars from R33 GTS
$20 pair
16. 2 BCT S600 tyres, 205/55/R16, flat spotted, camber wear, suit skids
$20 pair
Will post photos if I can find a camera that takes a smaller file size. Will also add itmes as I find them.
  • 4 weeks later...
Also for sale:
2 Pioneer GMD7400M monoblock amplifiers
2 Eclipse SW6010 10" subwoofers
Currently in car and can be heard running, one sub has had the surround re-glued to the basket over a year ago, good working order had no issues since.
Selling as a package for $400, pick-up or arrange a meeting place etc only.
2 subs and 2 amps as pictured:
(sorry for the poor picture)
  • 1 month later...
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
