got a set of extremely good condition r33 gtr wheels for sale!
brand new tyres!
located in doncaster east melb
will swap for r34 gtt rims + cash my way!!
chasing $1200,00
pm or get me on 0433005569
thanks
https://www.sau.com.au/forums/topic/392804-r33-gtr-wheels-as-new-condition/
You've got sms.
sms/call 0433878905
I am from Campbellfield. got a set of OEM GTT wheels with brand new tyres. bought for compliance only. . Can swap
cheers
Do you know by any chance if the R33 GTR wheels will fit an R34 GT-T?
brand new tyres!
chasing $1200,00
thanks
have you got pics of them fitted to the R34 GT-T? Would love to see if they would suit mine actually on the car.
Thanks
Jusitn
they r fitted on my gtt right now and fit perfect buddy
