Sure can, anything is possible in this world...
just a thought, what sort of budget are u thinking.
Have u googled this? Cause I have a feeling someone somewhere in the world have already done this
yeah,i did google it actually. I tried wording it a couple different way too. If any one has any success,please post up a link. Really love the wheels i have but they just need more dish. the back isnt to bad but they must have ran out of material when they made the frontsconfused.gif
https://www.sau.com.au/forums/topic/392921-more-dish/#findComment-6250650
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
