Hi guys since im selling some more stuff im putting my oil pump in here so please disregard that thred! also all standard parts came off my Series 3 R33 GTR.
Selling 4 x R34 GTT standard Rims their spraypainted black and the paint is all chipping off so they look crap but their still in good condition under the paint ( suit powdercoat etc) they have rubber but no tread at all need new rubber dont know a price to ask for so just hit me and the highest offer within a week can take them
4 x 25mm spacers bolt on looking at $180 ish ono
1x Trust High volume oil pump its brand new in the box still has sticky coating (anti rust) comes with crank seal and pump gasket need $1000 firm
1x Standard R33 GTR ecu not sure what their worth hit me with something and i might just take it :)
2x standard R33 GTR camshafts bit shabby $50
2x standard R33 GTR cam gears $50
1x set standard valvesprings + retainers $90
6x R33 GTR standard rods they will come with the pistons as no.1 is rooted and i cbf separating rods are all fine $100
have all 24 lifters some are rooted but some are still ok if you need some let me know and i can give each for $20 (as their $98 new from nissan EACH!!)
1x standard decent GTR waterpump $20 no leaks came off working perfectly
1x Turbosmart dual type boost controller the one with the 2 manual adjustments and in cabin missile switch for high + low boost... ( $100 ) ( you must come remove it urself )
Shoot me pm's most of the prices are not set in stone dont be afraid to offer ( within reason )
Cheers ! some pics of oil pump if you need pics of anything else ask and ill upload within the same day cheers!
Contact 0423755986 George ( after 6 weekdays )
https://www.sau.com.au/forums/topic/393448-gtr-parts-rb26/
  • 3 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
