1997 Nissan Stagea 260 RS
Pearl White
Rb26 twin turbo goodness with 85,860kms on the clock
4wd attesa and hicas
I have owned the car for about a year now, and in that time it has been a great car, but things change so it has to go.
It is fairly stock with only some light modifications done which include:
Engine:
Splitfire coils
Fujitsubo cat back
eboost-2 8psi (low) 12psi(high)
PWR intercooler (still have original)
Blitz bov (still have original)
Carbon fibre coil cover (still have original) and cam gear cover (not installed)
Exterior:
Nismo smoked side indicators (still have original)
Smoked Dolphin front bar indicators (still have original)
Interior:
Apline folding dvd head deck with navigation, Bluetooth, iPod connectivity
Soundstream components in the front and splits in the rear
Soundstream 4ch amp and mono amp
2x Soundstream 12in subs in box
Nismo gear knob (still have original)
Nismo center gauge cluster (still have original)
When i bought the car the timing belt needed replacing so that was done along with a new water pump.
It has also recently been serviced with new oil, spark plugs, fuel filter, air filter, oil filter
Rego is due in April and if not sold by then the plates GTRWGN are being replaced with standard ones.
Price:
$20000 ono
Contact:
Elliot 0405 418 342 call or txt or pm. If i don't answer when you call leave a msg and ill try to get back to you as fast as possible
https://www.sau.com.au/forums/topic/393992-fs-nissan-autech-stagea-260rs/
  • 3 weeks later...
  • 1 month later...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
