  • Replies 54
Great too meet up with you guys again....
Josh and Stayer - Good run back on the Princes Highway...All three of us occupying all the lanes with ZedGrl in front was cool...and the sound through the tunnels!!! We need a proper cruise soon...: :D
Added some pics on facebook: http://www.facebook.com/media/set/?set=a.374980292523644.84610.100000350281899&type=1
Apologies but they aren't the best, I'm not at all good with my camera.
Drag race you at the lights...which I believe Josh you lost..but I could be mistaken, cuz you started much further behind....
Yeah I thought that was what Josh was referring to. Since I saw him in my rear view mirror I'm pretty sure I was far enough ahead to claim victory but I stopped at the speed limit so figured I'd let Josh pass rather than cut him off...
yep, great meet
have you guys seen the crowd gathering at Warrigal Rd / Princess Hwy as you drove past there?
crowd didn't start to gather yet.. usually around after 10:30 - 11 is when the crowd starts showing up.
i believe opal you would've smoked me anyway so I'm just going to tell people i kept up with you
LOL
LOL
Well this is your club so if you want I can pretend that you beat me so you look good in front of your posse ;)
haha couldn't care less really =D
happy to lose to anyone with a nice car lol
Another good show for the V's (and the always welcomed Opal and her lovely Z).
Will be good to see all the headlights on, I defiantly got my work cut out getting lights rewired so they work normally. Anyone know a place that could get it done right?
Ya, good meet up night, see y'all the next meet! :D
Hey Tyler, sorry about the rat runs to the Westgate. I hate stopping at lights, LOL! Hopefully next time it be more a direct route than a rat run.
Tony, I found that document which tells you what each code of your 18 digit Nissan number means. I'll bring it along for our next meet. Alternatively, send it across and I'll try and interpret it for you.
Good to see the usual suspects and meet the new ones, funnily enough I headed to the drags the long way once we'd finished, must have missed that conversation...
Tyler, I'll probably approach Nuwan at IREV to do my lights and replace a window motor while its down there, he is friendly and by all accounts has done a lot of first hand work on V's.
I had no problems with the run out, yeah I kinda didn't time the lights very well, my bad. I was laughing so hard laughing-smiley-014.gif when the cop pulled out in front of you. I could tell you didn't want to go past him at all. Then I cut off that other Skyline coz he was driving like a grandma.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
