Switch Underneth Dash On Drvers Side Down By The Throtle 0N Rs4 Stagea 1996?
FFS
it heats the mirrors and wipers in snow
*calls b.s
Give it up Lucy, nobody's interested in your area of expertise (station wagons).
>_<:thumbsup:
Oh man! Did you rewire that switch to accommodate the s2 engine? I've seen this happen before. All I can say is uh oh!
You might want to sticky tape that button!
yea its still wired up i got a workshop ta put the engine in 4 me and its still wired up to the loom.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
