JustinP Posted March 11, 2012 Share Posted March 11, 2012 I have a brand new and unused FC-Datalogit for sale. The USB to serial converter that is provided by FC-Datalogit (as it works best with the unit) is also provided, as is a serial cable, driver and software CD and instructions. This is the latest model available and is perfect to get the most our of your APEXi PowerFC. Here are some of the features that the FC-Datalogit provides: - Works with all Power FC versions (No restrictions imposed on the number or type of vehicles tuned) - The FC-Edit software does all the things that the hand controller does plus much more - Log up to eight 0-5 volt analogue inputs - Connect to any 0-5 volt Wideband 02 Sensor and log A/F ratio - Firmware Upgradeable - Full size fuel and ignition maps (20 x 20) instead small sections - Lock /Unlock Apexi dealer protected maps and settings - Map trace and ghost trace - Rescale/Expand maps for high RPM and/or high boost applications - Adjust air temp correction tables - Saving and loading complete maps and fuel and ignition settings - The Power FC commander plugs into the FC-Box so you can still use it - Adjust the threshold for flashing the check engine or cat light for injector and knock warning $255 ONO including registered delivery Australia wide. If you are interested I am best contacted via PM, or alternatively on 0402 387 286. Cheers Justin Link to comment https://www.sau.com.au/forums/topic/394421-brand-new-fc-datalogit-with-accessories/ Share on other sites More sharing options...
stav Posted March 11, 2012 Share Posted March 11, 2012 I'll take it, will call today. Link to comment https://www.sau.com.au/forums/topic/394421-brand-new-fc-datalogit-with-accessories/#findComment-6270514 Share on other sites More sharing options...
JustinP Posted March 12, 2012 Author Share Posted March 12, 2012 Sorry mate, it sold first thing in the morning! I'll take it, will call today. Link to comment https://www.sau.com.au/forums/topic/394421-brand-new-fc-datalogit-with-accessories/#findComment-6271152 Share on other sites More sharing options...
JustinP Posted March 12, 2012 Author Share Posted March 12, 2012 SOLD!!! Pending payment by dysonest. Cheers Justin I have a brand new and unused FC-Datalogit for sale. The USB to serial converter that is provided by FC-Datalogit (as it works best with the unit) is also provided, as is a serial cable, driver and software CD and instructions. This is the latest model available and is perfect to get the most our of your APEXi PowerFC. Here are some of the features that the FC-Datalogit provides: - Works with all Power FC versions (No restrictions imposed on the number or type of vehicles tuned) - The FC-Edit software does all the things that the hand controller does plus much more - Log up to eight 0-5 volt analogue inputs - Connect to any 0-5 volt Wideband 02 Sensor and log A/F ratio - Firmware Upgradeable - Full size fuel and ignition maps (20 x 20) instead small sections - Lock /Unlock Apexi dealer protected maps and settings - Map trace and ghost trace - Rescale/Expand maps for high RPM and/or high boost applications - Adjust air temp correction tables - Saving and loading complete maps and fuel and ignition settings - The Power FC commander plugs into the FC-Box so you can still use it - Adjust the threshold for flashing the check engine or cat light for injector and knock warning $255 ONO including registered delivery Australia wide. If you are interested I am best contacted via PM, or alternatively on 0402 387 286. Cheers Justin Link to comment https://www.sau.com.au/forums/topic/394421-brand-new-fc-datalogit-with-accessories/#findComment-6271156 Share on other sites More sharing options...
dysonest Posted March 12, 2012 Share Posted March 12, 2012 sold. cheers Link to comment https://www.sau.com.au/forums/topic/394421-brand-new-fc-datalogit-with-accessories/#findComment-6271573 Share on other sites More sharing options...
