Im selling a 2000 Nissan Skyline ER34 25GTT project car that I purchased last year with plans on finishing it, but have been told that it has to go.
Car has 39,000 Genuine Km's - Full Logbook Service History (Last on the road December 08) and is Dark Blue Pearl (BP9) in color.
(PM me for the car build thread as it is on a different site (No live links allowed))
Car comes with the following parts:
350Z 6 Speed Manual with heavy duty clutch, Extreme flywheel and short shifter. $3750
VQ30DET NEO (30000km on the donk). $3000
2 x Ceramic coated Garrett GT2860RS (-5) Ball Bearing Turbochargers). $3000
Shaved: Boot, door handle locks, boot rear light, rear boot lock & all badges.
Ceramic coating of parts mentioned eg exhaust, turbo's etc. $1400
Custom 4" exhaust system (Same piping used on v8 supercars and NASCARS) with discreet dual tip and Metal Cat high flow cats. Custom Ceramic coated exhaust manifold and dump pipe.(Ceramic coated from dump to cats) [All ceramic coating by Chris at Craved Coatings in a Satin Black finish]. $6000
APS 350Z Twin Turbo Inter-cooler. $1000
Brembo F40 Front Brakes $5000 : - Brembo F40 Calipers
- ENDLESS Brake Pads
- 343x32mm RDD Rotors
- RDD alloy radial mounts
- Braided lines
- Calipers have had a seal kit and have been powder coated gloss black.
Tein Mono Flex Coil over suspension. $3000
Volk CE28N Wheels :- 18 x 9.5" Volk CE28N +22 (Professionally rubbed back, primed and refinished in high quality Glasurit 2 pack with a german clear coat to get the high gloss finish). $4000
Genuine 'Altia' front bumper. Bumper in average condition.
Re-sprayed engine bay and plastic engine cover by Naz @ KMF. $1000
Powder coated rocker covers, coolant pipe and alternator (Silver).
Genuine Nismo RB25DET engine mounts. $500 ea
Factory front guard and engine bolts replaced with hex head bolts.
Re-trimed door trims from cream to black suede. $500
Internal trims (gear shift surround, door switch surrounds, air con, air con vents, etc.) painted satin black.
HKS Half cage. $800
All that remains to be done to be completed, is wiring (Pretty sure the VQ loom is in a box), radiator, seats, drive shaft and engineering. Engine is in but not ready to run, as all the fuel lines and misc parts are in a box.
Manny more parts included, such as a Trust 'Grex' remote oil block adapter, Custom aluminium intake plenum (Unsure of origin). 2 x Spare Heads - Port & Polished. Heavy Duty valve springs. ARP head and main studs. O2 sensors. Gasket set. Old rear suspension and more bits and pieces.
Well over $35000 spent not including the car value.
Asking Price - $40000 ono
Not interested in parting out at this stage. Would like to see it go to a good home and get the attention it deserves.
Not included in the sale is the Focal speakers (As seen in thread).
The vehicle before:
Brakes:
Engine Bay:
Engine, Mounts and Studs:
Turbo's:
Exhaust and Headers:
Gbox:
I/C:
Suspension:
Outer:
Inner:
Heads, Gaskets engine internals:
Custom Ali Intake:
I can be contacted at [email protected], or on 0407 610 133 (Phone not on during working hours but will check after 4.30 PM)
Edited by vadgeviper
https://www.sau.com.au/forums/topic/394659-for-sale-r34gtt/
Obviously the market is quieter than I thought.
Can someone tell me what they think this is worth? Is it because it is no longer a 'true' skyline due to the engine change? Or is it because there is still too much work required?
Cheers
https://www.sau.com.au/forums/topic/394659-for-sale-r34gtt/#findComment-6336942
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
