for sale is my series 1 jzx100
mod list
exceedy hyper single plate clutch with lightened fly wheel
cusco coil overs
series 2 tail lights
cusco strut braces
slotted rotors front stock rear rotors with endless brake pads all round
hdi front mount kit
hks super scilent exhaust with high flow front pipe
wheels are 19 inch avs model 7 powder coated white
apexi cold air intake brand new in box
blitz bov is plumb back atm but the adaptor is there to make it vent to atmo all brand new still have the box
car still retains the stock air box with hks pannel filter
i have polished the cam covers /throttle body /water out let/and intercooler outlet the j pipe and inlet manifold is done in black wrinkle coat centre cover is mat black went for a stealth look less cop hastle
the car has had full major service last week done water pump all idlers and tensioner /timing belt/spark plugs /coolant/all oils diff has motul gearbox has redline shock proof engine oil gets done every 6 months or 3000 kms car does not get driven much as i get a company car and the misses drives this to and from work.
spare parts that come with car are all left overs i have from a part out of another 100 i bought there is all 4 doors with most parts still in them there is a spare boot with wing all door class and rear windscreen /2 front seats /a spare series 2 dash with no lift /stock exhaust 3 spare 19 inch tyres spare rear bar that has gay fog lights in it series 1 tail light thats all i can think of atm
$17000 ono
phone 0409454739
https://www.sau.com.au/forums/topic/395527-jzx100/
Free bump for a very tidy, and nicely subtle car: makes me miss my Chaser! thumbsup.gif
What's the mileage?
Is it factory manual or converted?
If converted, does it have the Torsen LSD?
https://www.sau.com.au/forums/topic/395527-jzx100/#findComment-6284548
car has 90 k on it i converted it to manual before x mass has torsen lsd out of manual chaser everything to do with conversion is out of a manual jzx100 pedals box diff tail shaft i went to the extream of putting the manual tunnel in it and manual ecu car retains the original cluster just has the manual black face on it as that is the only difference between the manual and auto cluster everything kept original
if anyone wants to check it out i am more then happy to throw it on a hoist at work and you can have a look
Edited by bernardshorty
https://www.sau.com.au/forums/topic/395527-jzx100/#findComment-6284579
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
