and is it for GTR, GTST, R32,33,34?
It currently has an RB26 map in it, but can be used for anything (only the base maps they are intially supplied with are car-specific).
Those who have asked, it's Version 2.1.
As for a price - I've no idea - make me an offer...
Phil
so what about wiring loom? how would you plug it into another car if it is setup for a GTR/RB26? I currently have an FCON V (non pro) on my R33 GTST (RB25DET, as i'm sure you'd know :P). Mine is a piggy back computer so the stock ECU is still in place to control the standard features. Would the one you have replace my standard ECU and FCON V or is it like mine and also a piggy back but more powerful? Where do you get it tuned, as HKS tuners are extremely few and far between
Cheers,
Andrew
Cheers,
Andrew
F-CON looms are cheap; I'm not sure if your existing loom would fit. I'm running F-CON V Pro together with the stock ECU at the moment.
You would need the correct HKS software to tune it.
Phil
OK cool... so it sounds like it's still a piggy back rather than a full replacement like the Power FC. Well i'll see if i can find out if my loom will work with the pro and if there are any other sensors i need as i am not particularly keen on rewiring the whole car. Also i'll check to see if someone i know still has the HKS software.
i'll let you know.
Guest
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
