Hi All..
I really don't want to sell this car, and even ingore wife's plea ..but now I have accepted an offer to work in oversea for 2 years (from March, 2005), and really have to sell.
2002 Imported, 62000KM was on the clock, now 78000KM.
It was total stock when I import back in 2002 ($22000), after years of saving and modified by sounded performance workshop in Sydney / Waterloo, all receipt available for inspection.
Looking for $28500 . Please PM me for detail or email me sidewaymambo at hotmail dot com, PICs available upon request. 0403228883 Phillip
Dyno sheet can be provide upon request
Spec as following:
1995 R33 S1 GTST, Dec built, Burgandy, Manual, regular service every 5000KM Mobil 1 only, timing belt / transmission oil/ LSD oil changed at 75000KM service.
ECU/Engine/Exhaust
Ported Head / valve
TOMEI 264 IN/EX cams
TOMEI adjustable exhaust cam gear
APEXi Power FC with H/C
APEXi RSM + shift light
GREDDY type R Blow Off Valve
GREDDY ProfecB boost controller
GREDDY Oil catch can kit
GREDDY engine oil cooler kit
GREDDY intake plenum
GREDDY Iriway 8 Iridium spark plug
Q45 90mm AFM
Q45 90mm Throttle body
NISMO Oil Cap
TRUST TD06-25g Turbo kit inc:
TD06-25g 16cm^2 Turbo
TRUST No'8 wastegate
TRUST exhaust manifold
TRUST Front pipe
NISMO 550cc Injectors
TOMEI R33 Fuel Pump 250L/H
NISMO Fuel Regulator
TRUST 3" front pipe and high flow catalytic converter
FUJITSUBO Cat-Back Exhaust
Suction and Cooling
APEXi Power Intake
TRUST V-SPL Intercooler kit: 600x300x76
custom stainless steel piping
Drivetrain
C's Quickshift kit
OS Giken twin plate clutch set (new installed by Bel, 500KM only)
NISMO big bore slave cylinder (make twin plate feel like stock)
Handling
TOMEI Brake Master Cylinder Stoper
FET Tower Brace (F)
CUSCO Tower Brace ®
DBA drilled / slotted disks (F,R)
Bendix advance / EBC brake pads (spare)
Motul 600 Racing Brake Fluid
Falken Azenis RT/215, 235(F) 255® 80% meat left
Belstien Shock / Whiteline spring
Section HICAS Lock Bar
Urethene suspension bushes (F&R)
Whiteline Handling pack (Full set)
Interior
APEXi EL Mechanical Boost Gauge
GREDDY Gauge POD
FET Turbo Timer
MOMO Steering Wheel
After market gear knob
Pioneer 5550 MP3 Head Unit
Pioneer 6 1/2" splits Speakers (F)
Pioneer 6" ®
RAZO pedal set
Mongoose M-M80 3 alarm + 3 points immobiliser
Exterior
R33 GT-R Style Front bar
R33 GT-R style front grill
R33 GT-R style bodykit
R33 GT-R Style Rear spoiler
Manaray 17" 6 spokes wheels
It really hurts me when someone spends over $40 000 dollars on a car then sells it for less than the cost of the mods. Mainly because my car doesnt have as many mods and I have spend over $40 000
sidewaymambo, if you ever decide to stock the car out (highly recommended) and sell the bits, let me know, I could be very interested in your brake setup, very, very interested. Even might trade for some stockers with endless pads
Free bump
Thanks, steve..I have set a dealine..if nothng happened..I will stocked the car..and you will on my top list..
do you still got the factory turbo setup with dump pipe, in/ex cams....just a ask..
cheers,
heh we're all in the same boat... I've a $50k R32 GTS-T. Philip is being a good dad these days, so he's selling this awesome R33... i'll probably put my car back to stock too b4 selling next time unless someone is prepared to pay decent money
free bump :)
p.s. don't sell b4 we go EC / wakefield together ! havent run with u yet heheh
  • 1 month later...
  • 2 months later...
I feel sad to put this ads, but that's life..trying to be a good husband / dad..
price updated..
free bump :D
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
