White Work Xd9 Wheels 17X 9.5 +17 Fronts With 225 45 17 Tyres 90% Tread And 18X 10 +18 With 235 40 18 85% Tread Disshh [Vic]
Hey guys,
For sale:
White Work XD9 wheels
17x 9.5 +17 fronts with Ovation 225 45 17 tyres 90% tread
18x 10 +18 with Zeta 235 40 18 85% tread.
Pick up only
Price $1900
Contact me by pm or call, txt me on 0470568767.
Cheers
Bob
Pm replied. Location VIC. Rims can be pick up at st albans 3021 or springvale 3171. cheers bob
Ahhhhh, I would take in a heartbeat but im located in Sydney :(. Are they multistud?
pmd, rims aren't multi stud, will sell to interstate buyers, if you organise your own courier. thanks bob
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
