Adam.
The ECU is all standard, I havn't got any engine management for fuel/Timing etc..
I use a bleed kit on the fuel pressure reg to help lean it out a little.
It is a pretty crude method to lean the fuel out but it seems to work, The afs arn't pefect.
i.e if you make the af's perfect up top then the mid range will be lean and loose power, make it perfect in the mid and the top end will still be slightly rich and loose a little bit of power.
Works ok but.. Its good for a tuning tool while you are getting you mods done. Then the ECU re-map will be done.. :D AFTER.. the new turbo..
Originally posted by Clint32
Makes top power at about 6k im guessing with the turbos running out of puff, good result though.
:D :confused: Hi guys i'm new here and i was wondering if you could translate 164Kw to me in horse power or teach me how i can do this myself being that im from Jamaica i am not use to this.:D
Originally posted by -Joel-
What causes the power curve to flatten out at the top?
the power curve angle, how long it levels out and when it drops off is pretty well determined by the cam. Duration, lift and overlap...
l¥le..
164 kw is 219.9 Hp, and that was at the rear wheels...
$500 every time you want to tune the car is pretty expensive
well at the moment im running stock injectors and a bigger pump so i think i might remap for 1 bar.... i cant afford injectors atm so depending on the results this may be the last mod for a while...
is there such a thing as "the last mod...." ?:)
Hey Joel....
When u finally put your new turbo on if u overlap the dyno readouts your new one will be slightly slower to make horespower but the curve will be more vertical andovertake standard curve. instead of flattening out at the end it should keep rising only just dropping at the end of revs where engine runs out of steam in that gear
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
