The Power Meter i-D is a unique monitoring tool that measures and displays horsepower and speed. The Power Meteor i-D is one of the only units in the world that can display both standard and metric measurements.
Power output can be display in HP, PS and kW. Speed can be displayed in MPH and km/h. Both power and speed can be displayed in digital and graphical form. The Power Meter id also has a Chassis Dynamo function, which plots Horsepower to Speed in a graph form.
Power Meter i-D also has the ability to time the following
0-50mph (0-100km/h), 0-100mph (0-200km/h), 0-200mph (0-300mph)
0-1/8mile (0-2--m), 0-1/4 mile (0-400m), 0-5/8 mile (0-1km)
The Power Meter i-D also has the ability to record and data log up to 5 different times.
Features:
Compact 1/2 din size
Chassis dynamometer (up to 1183hp)
Reads speed in mph or km/h (up to 249 mph or 399kph)
User adjustable brightness and contrast
Easy to read illumi-drive (i-D) white lighting
Easy 3 wire hook up (attaches to stock speed sensor)
Compatible with naturally aspirated and turbo charged vehicles
Product has never been opened
Still In Box
Pictures available on request
$450
RRP: $495
Make an offer, and not a silly one
Thanx
https://www.sau.com.au/forums/topic/39793-fs-blitz-power-i-d-meter/
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
