no....
i got out of rc to found my riceline , and just bought one off a mate or 50 bucks , its just an e10 , crappest hpi of all , but for drifting it doesnt matter as much , i got it for 50 bucks , i can get you a mates car the same as myne for 100
but generally speaking you can pick up a nice car second hand for about 250 , if you want a brand new setup , and something pretty descent probly 400 mark , then if you wana get serious , like an mi2 or a cyclone and for a complete brand new setup your punching above the 500-600 dollar mark , thats full carbon belt driven setup.... technicly..not needed , who cares but man just buy one like myne , and have fun it does pretty much the same thing as something with billet an carbon parts , there isnt much difference at all , if you want a car shoot me a text 0421652234 and ill hook you up.
Edited by Savtraxx
nothing wrong with used cars
im not gona argue about 20 of the 25 cars ive had were used , thats like saying dont buy a used real car?
makes no sense....
so anyway , anyone else?
no...
it's like saying don't buy a used drift car, you wouldn't expect it to be it good condition would you?
if the drift cars that you bought used were in good condition the people you bought them off clearly were not trying hard enough.
also lol.
I'm in the process of selling my setup for $600 to an interested SAU member.
It's been used once and is setup for 1.6 c/s.
http://www.sydneyrcdrifters.com/forum/viewtopic.php?f=60&t=11251
Doesn't come with electrics but we can discuss if the buyer would like a ARTR setup.
i bought my cyclone off a guy who drives for hot bodies was setup very well , honestly im not good enough to keep it setup like he had it , i never raced it tho... i have owned my baja for 4 years now thrashed the guts out of it jumped it as big as it would go.. but ive also poured about 6 grand into it
its now for sale fully rebuild with all new bearings and almost new engine , rebuild shocks , diff etc.....
theres thrashing a car and not taking care of it and thrashing a car and having just as much fun keeping it in top nic after you've done killing it
your dribbling...............
real drift cars are mostly drift p igs...
but look at someone like.. mad mikes fd drift rig.... kept in a1 spec...
rc cars are normally ...NORMALLY kept in good nic cause its cheap to do so unlike real cars
i have bought so many second hand rc's
3 e fire storms
cen matrix truggy with lrp .30 in it
2 bajas
rock crawlers
cyclone
losi mini and micro t's
boats...
list goes on , i checked all of them before i bought and the owners kept them in good nic....
so "no" yourself ..........
thankyou :)
tw@
Edited by Savtraxx
  • 4 weeks later...
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
