Time to clean out the garage.
For Sale-
R32 GTR Tein Super Street Coilovers done about 2000 km's $1200 ono
Nissan optioned fog lights $200 ono
Greddy Cooling pannel has minor scratches $50
Mines R32 gtr ecu tuned for 98 $200 ono
R32 standard swaybars $50 each front and rear
Hicas Pump and lines $50
UAS cradle lock kit for r32 Gtr $50
Nismo Clear indicators Brand new $150
R32 gtr Standard wheel $500 with tyres
R32 gtr radiator $200 ono
JJR rb26 front pipes $150
R32 gtr aircon core and pump $100
R32 driver side head light new $200
R32 passenger headlight s/h $50
R32 gtr front bumper $300 ono
Stanard rb26 turbo pipe $50
rb26 front cam gear cover $100
pm me or txt on 0439337001
https://www.sau.com.au/forums/topic/398175-garage-clean-out/
Also have for sale.
Gtir SR20 engine has low compression suit rebuild $500 ono engine has done 128000 km
r32 gtr hks pillow ball strut tops $100 ono
EL sport coil overs to suit r32 gtr suit rebuild, bilstein internals $200
RB26 fuel rail $80
gtir fuel pump $100
gtir fuel injectors $200
gtir standard ECU $150 ono
  • 4 months later...
***Updated***
For Sale-
Mines R32 gtr ecu tuned for 98 $150 ono
Nismo Clear indicators Brand new $100
JJR rb26 front pipes $100
R32 gtr aircon core and pump $75
RB26 fuel rail $80
gtir fuel pump $100
4 x 444cc gtir fuel injectors $150
Extreme Torque Split Controller $150 ono
Xbox 360 Black 120 GB Hard Drive with 3 games and two controllers $200
Standard Rb26 Ex Manifolds $250ono
  • 3 months later...
For Sale-
R32 GTR Tein Super Street Coilovers done about 2000 km's $900 ono
RB26 fuel rail $80
gtir fuel pump $80
Standard Rb26 Ex Manifolds $200ono
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
