Apexi RSM - Black edition - 8mths old, no scratches - in absolutely perfect condition. Currently fitted to my R33 GT-R = $250 + shipping
Ferodo DS2500 front pads, part # FCP1298H - still in the box. These are extra for me due to a stuff up with postage that forced me to urgently buy a 2nd set = $210 + shipping
ATTKD 2-piece front rotors, 324mm - slotted - for Nissan Skyline GT-R. These fit R32 GTR V-Spec II (Brembo Caliper), R33 GTR R34 GTR. Condition of these is brand new, still in the box - not even test fit was attempted. On the net these go for $499 + shipping = here its $490 + shipping
Need to improve my financial situation so these are up for sale.
Please PM me if interested.
Cheers
DS2500's - $200 pick up - you can't find this cheaper anywhere so for all the Melb based people its a great opportunity. PM to organise a pickup.
ATTKD's - if you get this online it wil set you back $529 with shipping - pickup only - $490. PM to organise a pickup.
Brand new, still in the box - front DS2500's - $180 firm. Pick-up only. Melbourne CBD or Ringwood area - PM if interested.
If you are after an unbeievably good brake pads, perfect for track days and for daily driving then you can't go past these, and for this price they are a steal.
Still here - still ready to go - awesome pads - really love these on track or the roads - brand in, still in the box.
Bump
Get some great pads for your Brembo calipers.
Bump
Bump
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
