Apexi RSM - Black edition - 8mths old, no scratches - in absolutely perfect condition. Currently fitted to my R33 GT-R = $250 + shipping
Ferodo DS2500 front pads, part # FCP1298H - still in the box. These are extra for me due to a stuff up with postage that forced me to urgently buy a 2nd set = $210 + shipping
ATTKD 2-piece front rotors, 324mm - slotted - for Nissan Skyline GT-R. These fit R32 GTR V-Spec II (Brembo Caliper), R33 GTR R34 GTR. Condition of these is brand new, still in the box - not even test fit was attempted. On the net these go for $499 + shipping = here its $490 + shipping
Need to improve my financial situation so these are up for sale.
Please PM me if interested.
Cheers
DS2500's - $200 pick up - you can't find this cheaper anywhere so for all the Melb based people its a great opportunity. PM to organise a pickup.
ATTKD's - if you get this online it wil set you back $529 with shipping - pickup only - $490. PM to organise a pickup.
Brand new, still in the box - front DS2500's - $180 firm. Pick-up only. Melbourne CBD or Ringwood area - PM if interested.
If you are after an unbeievably good brake pads, perfect for track days and for daily driving then you can't go past these, and for this price they are a steal.
Still here - still ready to go - awesome pads - really love these on track or the roads - brand in, still in the box.
Bump
Get some great pads for your Brembo calipers.
Bump
Bump
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
