  • Replies 151
Can you advise if the suspension is still available?
If so can you advise what they are and how much you want for the set
Which suspension?
S14/s14a genuine ganador mirrors still forsale?
Sold ages ago.
For everyone who keeps asking for shit I've already sold - the stuff below is all i have for sale now:
New parts
Mazda Air temp sensor (for PowerFC D-Jetro) (brand new) $120
S14a HKB boss kit with airbag light cancel resistor plug (brand new) $180
S14 'Edge' Side skirts, unpainted white gelcoat (brand new) $250
S14.5 Origin +25mm conversion fenders (brand new) $450
S14 Origin +50mm rear fenders (brand new) $450
S14 light weight fibreglass doors (brand new) $900
S14 Full Lexan window kit (rear window with NACA vents, rear quarters, driver and passenger door windows with slider window kits) (brand new) $1,050
used parts
Greddy engine oil cap $40
S14/S15 Nismo springs and struts (lower than factory, very comfortable on street) $550
S15 factory rear boot spoler with led's, pewter colour $120
S15 JDM factory steering wheel with airbag $230
S15 Hybrid aluminium radiator $250
S15 Stage21 aero front bar (painted blue) $300
S15 boot lid and ducktail spoiler (not separating, duck tail is sikaflex'd and bolted on to boot lid) $300
S13/180sx TRUST 19 row oil cooler kit, thick quality trust core, for S13/180sx with filter relocator $700
HKS Super Sequential SQV BOV, genuine HKS, mounted on evo 8/9 hot pipe $300
ATP 'Frank' turbo, with stainless steel manifold, will fit s14/15 SR20det, good for around 240-250rwkw with stock cams. Braided lines included. $1100ono
C-west genuine carbon fibre GT-wing, mounted on S15 boot lid, wrapped in matte black vinyl $1,100
R34 GTR Cusco Type-40 aluminium strut tower brace $240
R34 GTR C-west N1 front bar (genuine), carbon fibre (painted black), will need respray/minor repairs $750
R34 GTR C-west carbon fibre cannards for N1 bar $350
R34 GTR/GTT Nismo GT LED tail lights $1,200
R34 GTR Alcon 6-pot front 365mm brake kit, rear 330mm brake kit. Ferodo DS3000 pads all round $6800
4x Advan AD08 265/35/18 tyres 99% tread (almost new, less than 300km) travelled $1300
RAYS Nismo LMGT4's white 17 x 9 +22 all round, no tyres, concave spokes, clears GTR brembo and Alcon brakes to 335mm rotor $2,200 firm
RAYS LE37's Top Secret Limited Edition Gold 18 x 10.5 +15 all round (rare, don't really want to sell these) $4000
SSR Type-C 17 x 9.5 +15 PAIR ONLY, white, average condition for age, no buckles $1100
** can post wheels interstate if needed at buyers cost **
New parts
Is this kit a plastic 4 performance kit from the uk, if it is there kit is it the clear kit with 5mm doors and 4mm rears with the budget sliders.
Matt
Hey mate, could not PM you,
can you send me a pic of your GTR/GTT led tail lights to [email protected] and how much is postage to sydney? - remove the . after the k
