g'day all, sorry to make my first post a bit of a know-nothing question, but i'm really really interested in getting the hatchback R30. there are very few around and in the past six months only two have popped up in tasmania, the first one was great and reasonably priced, but devastated, i just didn't qute have the money at the stage. another appeared on gumtree just a few weeks back, it was a manual and ticked all the boxes, but to my disappointment was one of the 6-cyl 2.4 models, without the aircon, power windows or central locking. their fuel economy (according to the depths of the internet) is pretty terrible and in my situation i am willing to fix parts but not have such a high ongoing cost. my question to any skyline veterans is... how often do these come around in your experience? are the 1.8 ltr 4-cyl only automatics? should i wait? i have become obsessed but don't have a car at the moment and am considering getting something in the meantime, but i just can't let them go and nothing compares!
thanks in advance, joe
EDIT: also, one of my other options is this reasonably mint 1982 datsun pulsar, i'm not 100% about whether i can talk about things other than skylines but here is the link: http://www.tradingpost.com.au/Automotive/Used-Cars/AdNumber=TP004786325 ... anyone know much about them? it seems like a bucketload as a saw one with similar k's go for $800
Edited by atko
https://www.sau.com.au/forums/topic/398637-1984-r30-hatchback-ti-questions/
ALL of the R30's sold by Nissan in Australia were 6cyl 2.4E versions and you're right, the economy is fairly poor off the shelf. To my knowledge we in Aus never got the 1.8 version unless by private import.
As for the N10 Pulsar ...... Are you an enthusiast, or do you want just a car to drive?
That N10 is farely rare in that form (coupe) and with 189K on the dial and from the description, I think it's a GEM. I had a 2 door sedan once and it was a fun thing and with a little bit of effort you could make it something special. And they are quite economical.
Remember though, it's a small car and if you need a car the size of a Skyline, the N10 wont cut the mustard, but if you're looking for something as a get about, you van do a lot worse.
If you have the money, grab it before I go to Tassie and beat you to it.
Cheers, D
  • 1 month later...
http://www.gumtree.c...alue/1002041586 here is the skyline, just as an update that i ended up buying... it's a dream. really good nick. i had my mechanic check it out and he reckons it's a 'solid unit', had no problems for the last month and i couldn't want much more. fuel efficiency turned out to not really be a problem. i was also coming back to this topic, instead of starting a new one, because i was wondering if anyone was wrecking one of these model skylines or new a good place to get parts? i sort of would like to put in a new glove box and maybe other parts too, i just want to bring the interior back, because it has a few solid scratches. (on that note, does anyone know a good way to get them out without having to replace the sections?)
thanks
  • 5 years later...
thanks
Still available  ur car?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
