Sell My HKS GT3037
Still on car. well on engine (engine out of car) did not plan on selling but Dream turbo set-up has come up for sale so if i sell this i can get the turbo setup i want..
Turbo is fine does not blow smoke and at 16 psi gave me 304kw on 1jz manual
Melb
Contact via PM or 0431152295
Price $1000 Firm
Any questions feel free to ask
Any a quick picture of it via facebook if you want more detailed shots feel free to ask and i will take some Saturday when i get home.
https://www.sau.com.au/forums/topic/398673-hks-gt3037/
The HKS GT30 Series Turbo - GT3037S Turbine is quite popular among the high power drift cars because of their balance of response and power. The HKS GT Series Turbos are based on ball-bearing Garrett units and like the HKS Signature Series have re-engineered compressor and turbine wheels along with specific A/R and trim levels. All GT Series Turbos are designed to be a perfect blend of power and response. HKS achieved this balance by first choosing to use a ball-bearing center cartridge to reduce friction along with an off-center turbo design for improved efficiency and flow. Next HKS carefully tested Trim and A/R levels along with different inlet and outlet diameters to achieve optimal power. The results of this combination are turbos that not only deliver amazing power, but also spool incredibly fast.
HKS GT Series Turbos are offered with a GT25 (T25) and/or T3 footprint and the turbine wheel is constructed of inconel. Inconel is a very expensive material that can withstand extremely high temperatures and is typically only used in the aero-space industry and on race cars.
Specs of mine off top of my head will confirm when i get home tonight
SPECIFICATIONS:
Turbine Model: GT3037S
Turbine Type: Ball Bearing Type
Compressor Wheel (mm):
- Trim: 56
- Inducers: 55.0
- Major: 76.2
Compressor Housing (mm):
- In Dia.: 100
- Ex Dia.: 50
Turbo Wheel (mm):
- Trim: 84
- Inducers: 60.0
- Major: 55.0
Turbo Housing:
- In Flange: GT25
- Ex Flage: GT30
A/R:
- 0.87: 12cm2
PRODUCT NOTES:
External Wastegate Type
All right as you see in pic i run a 1JZ on 16PSI i made 280rkw 18psi 304kw
on 16psi i was making full boost by 3800rpm and at 4000rpm i had 200rwkw so a very responsive turbo and still making power at 7500rpm (my safe limiter) wind boost up more rev harder and you have a very awesome power band
https://www.sau.com.au/forums/topic/398673-hks-gt3037/#findComment-6332762
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
