For Sale (NO TRADES PLEASE) unless 2008-2010 BMW 335i Wagon
FPV F6
2009 Model
35,000km's
Full service history
Oil & Filter changed every 5,000kms
Excellent car in excellent condition.
Bluetooth
Set up for a tow bar - Has not been used for towing.
Tinted windows
Parking distance control
Selling due to lack of use
Sits in garage now collecting dust
Plates do not come with car.
Car is located in VIC
No modifications
$41,500 will come with RWC
PM if interested.
Edited by macdog
https://www.sau.com.au/forums/topic/399143-fpv-fg-f6/
FPV F6
2009 Model
35,000km's
Bluetooth
Tinted windows
No modifications
PM if interested.
Few things I missed,
Color - EGO (Gun metal grey)
Black leather interior
Ipod connection (factory)
Mp3 player (factory)
6 stacker CD player (factory)
As I said totally stock, only run on BP ultimate petrol.
https://www.sau.com.au/forums/topic/399143-fpv-fg-f6/#findComment-6340784
  • 3 weeks later...
FURTHER PRICE REDUCTION
NOW $37,900
Bloody tough market at the moment. Car is also advertised on carsales!'
Will still trade for 2003-2005 BMW M3
Phone Number: 9593 three zero zero 9
Edited by macdog
https://www.sau.com.au/forums/topic/399143-fpv-fg-f6/#findComment-6425645
NOW $37,900
STILL FOR SALE!!
https://www.sau.com.au/forums/topic/399143-fpv-fg-f6/#findComment-6435647
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
