Hellow everyone,
I hope am posting in the right section of the forum.
I have R33 Series II GTST that has a Front Mount intercooler , Boost controller , Pod filter intake , Bov, Haltech Pro Plus ECU, 3" exhaust , upgraded turbo etc etc.
Now am having trouble with the car during startup. The car takes about 5-10 seconds of ignition.
I have already cleaned intake and throttle body and AAC valve as well.
My R33 has very different throttle body and half of the wires / plugs are not connected.
AAC valve is also different on this car and the wires having no plugs attached to it.
Please see this pictures attached.
Any help will be highly appreciated
thanks
https://www.sau.com.au/forums/topic/399457-cold-start-up-problem/
Has it always had this issue or just started? Is there plenty of fuel getting to the fuel rail?
Does it start with some throttle applied?
Few possibilities is the fuel pump, fuel pressure regulator. With the reg u could try crimping the return line as u are attempting to start it
Thanks for the reply
its just the ignition Issue
Nah it doesnt get started by applying throttle its just long long startup!!
Its tuned @14 psi , it was perfectly fine till last week! , I don't know whats wrong I just cleaned intake and sensor thought it could be that.
Should I try replacing a fuel pump ?
BTW it has Cusco Fuel Catch can too (this thing is too complicated compared to one nice stock skyline I imported last year) :rolleyes:
Ok that tells me it is a fuel supply issue. Try crimping the retun line before starting.
Also take fuel line off before the rail and the amount of flow when priming.
If u are near me i could check it out with my pressure and flow gauge
I guess that could have been the problem
Okay let me explain
2 weeks ago I added Nulon Fuel Injector cleaner , Drove car back and then parked ( sunday)
Monday morning 7.20 am I started the car 1 failed attempt
2nd attempt it took about 5 second of starter motor's effort to give me a hope that this thing is going to turn on
3rd attemp was successful
So now after I wrote the reply went to Caltex and got about 20 litres of Vortex ( last time i used BP ultimate)
Car was warm and it started smoothly
so it can be a fuel issue too I suppose
I've got it service like a 1000kms ago and had changed oil filter , fuel filter , pod filter , engine oil (10w50) and other necessary things.
I shall see tomorow morning if it work properly
thanks again for the help mate. appreciate it
am in melbourne and you seem to be pretty far :(
Fuel cleaner could have dislodged some crap and its stuck somewhere else now.
Hope its not blocking an injector. that would be bad.
I had issues with my cold start circuit, so i stuffed half a Nerf dart in the pipe. Much better but not fixed.
If you wait for the fuel pump to prime the rail, does it start easier?
thanks mate
Yes I know now what the problem was!
It was that crappy Nulon Fuel injector cleaner
I used it 2 weeks ago and since then I had that problem
Yesterday I even cleaned intake of my car and then went for a drive , filled 20 litres of vortex ( last time I used bp ultimate)
and this morning car started normally!
Thanks guys for your help really appreciate it :)
    • Yea my thought was tighter engine when hot is more load a poor ground connection can't take. On that note, I had time to check my driveshaft verical alignment tonight, it's +2 and -2 at either end, so thats perfect and how I had set it up last year. What would be the easiest way to check horizontal alignment between my diff and transmission? I can think of a few ways but they're all complicated and I feel like I'm overthinking it. I'm hoping it's that as I can't see any other reason why I have developed driveline vibration since I put the motor back in.
    • Thank god. I thought I was the only one, nobody seems to mention this (cause nobody really goes this far in Sedan land). The car's track is 10mm wider at the rear, which explains why the rears sit a little further out for the same size wheels. There's not really many options in widebody land for sedans anyway - People will just use whatever came out of the box and then buy wheels/spacers to suit. To get it perfect you'll likely need custom wheels with custom offsets if you really want to get it perfect which is what I plan to do, but I also plan to utilize more of the inboard space for tyres at the rear... which is also something nobody ever seems to do.... OR my maths have failed me after 20,000 attempts and I'm about to make huge mistakes.
    • What colour is that?  A mate of mine went red/black on his SLR5000 tribute recently also.  And yes, also glad to see this still progressing albeit slowly.
    • found a company that makes a flat gauge face 3-d printed mounting base kit to eliminate the dished style gauges. if anyone else is looking to do the same https://www.dashfreaks.de/shop/flat-dials-holder-nissan-skyline-r34-gt-gtt/
    • I installed my link ecu shortly after. But car ran fine with stock ecu and r35 coils, just had the traction control and slip lights on.
