[Vic] Stock R34 Gtt Rb25Det Bov & Crossover Pipe.will Suit The R33 Gtst Also. Can Post Oz Wide!
Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit. -
Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
