My skyline has a 2.5inch cat back exhuast system with a muffler just before the diff, then it turns into a 3inch straight pipe. If i was to get the Stainless steel drift pipes welded on the back 3inch inlet to a Y section into 2 3inch pipes would this affect anything but the sound? If i had the money I'd re-do the system but i don't so just wondering, thanks.
https://www.sau.com.au/forums/topic/400360-exhuast-question/
shouldn't affect anything to drastic man you wouldn't be flowing enough now to out flow the current system so i wouldn't worry about the extra pipe being added.
as far as noise goes should make it a fair bit louder and on a natro thst system will be WAY over the legal db reading... also if your gona be fully hella flush sickness and stick them out a foot past the rear bar copas will hate you, and expect to be pulled over alot...
tldr, won't affect anything, will be louder and illegal
Okay well, its only costing around 90 to get it welded on and have the piping moved around so thanks. As for it sticking out, I'll prob just cut more into the rear bar so it can fit out and have it pretty flush to the back of the rear bar, already got enough defects as it is.
its not as much about pipes as it is mufflers, one muffler in a system will always make loud regardless of pipe diameter.
think mufflers and resonators for adjusting sound, and pipe diameter as adjusting flowcapabilitys
pipe size will always have an effect on noise though, even after the muffler. the more restriction in an exhaust, the more effect the muffler will have. this is why with a big exhaust you often get a drone at low rpm. there isn't enough restriction to really quieten it down. also the amount of echo that you get with bigger pipes. twin 3" pipes will be mega loud. twin 2" pipes will still be pretty loud, but not as loud.
if the car is a natro (hence posting in here), and an r32 (according to your profile, then anything above 2.5" on a 2L engine is a waste of time and you may well be losing low end power. 2.25" would be more than adequate for a 2L engine unless you spend all your time on the track at high rpm.
Okay thanks, yeah its just a rebuilt RB20DE the current 2.5inch system is what was on it so don't really want to pull it all out. Im going to sell the tips. and run a single stainless steel pipe from the muffler of 2.5 inch might make it a little better.
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
