Year: 2000
Make: Nissan
Model: AUS Delivered Silvia Spec R
Kms: 127xxxkm
Transmission: 5 speed manual
Rego: Can be supplied, road worthy included
Description/History:
Up for sale is my 2jz powered S15. I’m looking at buying a house or rental property so this must go. This is an extremely quick car yet still can quietly drive around town without any hassles. I am the 3rd owner since the conversion was done. There are a few Nissan S15 in Australia with this conversion, so this is a chance to own something very unique. Engine, gearbox, turbo and FMIC are mod plated/engineering certificate.
The car makes 458.9rwhp @1.2bar. The only drawback from the car making more power is the undersized fuel system. With bigger injectors (1000cc can be supplied at a price) and maybe a surge tank, power figures could be around the 550-600hp mark without drawing a sweat.
No expense spared when servicing with recently rebuilt turbo (over $1000), new steampipe manifold and turbo gaskets. Rebuilt power steering pump with new lines rated to 2800psi. Rebuilt clutch by NPC. New timing belt, new serpentine belt for alternator and p/s. New oil cooler. Near new KUMHO ECSTA XS semi slicks tyres ($800). Serviced every 5000km with full synthetic oils and new coolant
Exterior:
Factory Pearl White
Factory Sunroof
Factory Spec R side skirts
Carbon Fibre Boot Lid (factory boot supplied)
Front Chin Lip
Engine:
2JZ-GTE
Custom engine mounts
K&N POD
4 inch intake
Innovative T76 Turbo (ceramic coated)
Braided turbo cooling lines
Steam pipe exhaust manifold (ceramic coated)
68mm external wastegate w/ screamer (ceramic coated)
4 inch dump pipe (ceramic coated)
3.5 inch straight through exhaust
Varex Muffler
FMIC
Custom IC piping
80mm throttle body
Greddy copy plenum welded on to factory runners
Aftermarket radiator
Twin thermofans
Oil cooler
Catch can
Magnafuel pressure reg
GTR fuel pump
Removed A/C pump
Engine dampener
Standard 430cc injectors
ECU/Electronics:
Haltech E11v2 ECU
Blitz Dual SBC spec R
Blitz racing boost meter DCII
Gearbox/Suspension:
R154 gearbox
Custom gearbox mounts
Custom OS Giken super single plate
V8 supercar style thrust bearing
Push pull type clutch slave kit
Custom J shifter to suit interior
Trust shift knob
Custom one-piece tail shaft
Factory LSD
Project Mu NS rear pads
Factory suspension
Strut brace
Wheels/Tyres:
Black Racing Pro N1 17x8 fronts, 17x9 rears
Kumho KU36 ecsta xs semi slick 235/45 front 255/40 rears
Forged wheel lugs
Pictures:
http://i561.photobucket.com/albums/ss58/666CEF/IMG_8041.jpg
http://i561.photobucket.com/albums/ss58/666CEF/IMG_8284-1.jpg
http://i561.photobucket.com/albums/ss58/666CEF/DSCF3970.jpg
http://i561.photobucket.com/albums/ss58/666CEF/classifieds-67260-0-44854700-1337054629.jpg
http://i561.photobucket.com/albums/ss58/666CEF/DSCF3974.jpg
http://i561.photobucket.com/albums/ss58/666CEF/DSCF3901.jpg
http://i561.photobucket.com/albums/ss58/666CEF/IMGP2693.jpg
http://i561.photobucket.com/albums/ss58/666CEF/IMGP2705.jpg
http://i561.photobucket.com/albums/ss58/666CEF/IMGP2721.jpg
Price: $27000 Firm
NO SWAPS.
No test pilots, a deposit will be needed for test drives.
Serious inquires only.
No Lowball offers.
Contact: PM me or Call/MSG on
  • 3 weeks later...
  • 4 weeks later...
  • 2 months later...
  • 2 months later...
  • 4 months later...
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
