Brought this car with stock rb25det engine and gearbox and with coilovers and a little bit of other basic stuff. Was originally rb20E gayness. Since then it's had a few ups and downs and is currently sitting on random skidders under a car cover awaiting pre-matsuri mods! Before matsuri I want to re-wire the engine loom, clutch needs to be sent away to NPC to beef it up abit, Need wheels and a few other bits and pieces but nothing major. All will come with time and money. Makes 368hp on 18pound which makes me happy. Have a 3076 to put on and a z32 so hopefully will crack 400 next tune on pump fuel
Motor
Rb25det
T04e ebay turbo (havnt had any trouble with it)
Braided turbo feed line
x-force high mount manifold
40mm gate + screamer pipe
EVERY seal in the head has been replaced (half moon seals, both intake plenum seals, manifold gasket etc etc)
3 Layer metal head gasket
Custom water lines
780cc high flow injectors (cleaned and flow tested)
ARP headstuds
Heater and A/C removed.
New century Battery
14” thermo fan on switch
50mm Radiator
alloy catch can + overflow
Oil cooler with relocator kit
Heads been decked and cleaned
Spit fire coilpacks
Excedy ceramic 3 puk clutch
D1 catch can
Big front mount
Pretty much every new hose/line
Interior
Pioneer head unit
6” pionner speakers in front doors
Apexi oil temp and water temp gauges
Drift button and bike grip on handbrake for the bitches
R32 front seats
Monkey floor brace
Laurel floor mats for confusion..
Power Fc computer with hand controller
Deep dish steering wheel
Dilly gearknob
Cusco front and rear strut braces
Drivetrain etc
Rb25det gearbox
G4 fully adjustable coilovers all round
R 180 welded diff FTP!
Adjustable castor arms
Adjustable camber arms
Adjustable toe rods
Full 5 stud conversion maintaining drum hand brake
S14 brakes
R32 rack ends
R32 tie rod ends
Power steering rack has had full recondition
Outside
Origin roof wing
Speed dint in the quarter from a racing pidgeon
395777_10150533074612279_725607278_10867587_631917301_n.jpg163622_10150105193452279_725607278_7748994_2263260_n.jpg
https://www.sau.com.au/forums/topic/402257-juzzos-ceffy/
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
