Why don't you try telling us about the car on this page like, modifications, location, price, history etc...
some people might bypass your link..
May help, who knows :wacko:
Edited by twistedr33
Ok good idea :)
here we go
Mitsubishi Lancer Evolution 8MR (Import)
Car was built by ChasersMotorworks in Melbourne if you want to know a bit more about the history feel free to call them.
The list of modifications is as follows:
Engine Modifications:
- HKS 2.3L forged stroker kit.
- HKS 3037's turbo kit/external wastegate
- HKS manifold
- HKS type R intercooler kit
- HKS type R oil cooler kit
- Tomei 800cc injectors
- Tomei adj. cam gears
- Tomei Procam 270/270
- Hypertune Intake manifold
- Hypertune throttle body
- Tomei fuel rail, braided fuel lines
- Sard fuel regulator
- PWR 57mm radiator
- Ferrea oversize valves, guides, springs,
- Solid engine mounts
- Heavily ported, machined, polished head
- Motec M800 ECU
- Tomei Sump baffle
- Solid lifters
Suspension/Handling Modifications:
- Ohlins Flag L coilover suspension w/external res
- Alcon monobloc 6piston 365mm front brakes
- Alcon monobloc 4piston rear brakes
- Rose jointed
- All aftermarket suspension arms
- Adjustable sway, camber, toe, castor, bump, rebound etc
- Summit tower brace
- Summit boot bracing
- In cabin floor bracing
- Under car bracing
Drivetrain modification:
- Cusco front and rear Differential LSD's
- ORC twin plate carbon clutch
Aesthetic Modifications:
- Full Varis Time Attack Version Widebody Kit
- Chargespeed carbon bonnet
- Varis carbon boards under sideskirt
- Carbon canards
(Stock body kit will come with car)
Extras:
- Rays RE30 10.5x18 wheels
- Bride bucket seats
- Sabelt harness (currently not installed)
$38,000 ONO,
Will consider swaps.
Cheaper for guys on here, as i have alwasy lurked here for advice !
If I don't answer please email or text as I work weird hours.
(Photos of Car are missing sideskirts because it makes life easier to put it on a hoist without them on, they will be included with the car)
Car comes with plenty of Extra's and spare parts !
If you'd like more photo's send me your email.
Thanks for looking.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
