got a reaper up top of my arm, started on my sleeve, still have 6 hours ahead just to finish the shading on him, but hey be worth it :D
after this is done in next fortnight focus is back on car parts again haha
On builds just acquired all my parts required to finish off my first stage of engine mods..
Doing decent service on it before ebc, cam gears and tune happens next month... Heaps keen!
What EBC did you end up going with or still deciding?
Do you still need those cam gears Ant?
what else do you need for your future -9 upgrade? i have a few parts lining around (new injectors, can prob get you my old(but new) vipec ecu cheap too)
Hey mate, don't need the cam gears anymore sorry mate, ended up getting some new tomei ones for a really good price, they turned up today.
Ah roughly for the -9 upgrade would be adding:
Turbos obviously ha
Different ecu
Injectors and pump
Clutch
Think that's about it, kinda gong/hoping for a simple but effective build.
Yea those parts sound interesting mate if they would suit the above?
What about oil pump for oil starve ant??
Don't you need lots of supporting mods in a gtr?
Yea havent looked into whats required for oil etc yet too much, i know there will probably be a few little extra supporting mods to do when the build happens.. but at this stage mainly concentrating on whats required to make my power goal, then go from there as its still quite a way off.
Not sure if i need to go crazy with it though as its not a track car, if i was making it for track then yea i would go crazy with that stuff.
Turbos obviously ha
Different ecu
Injectors and pump
Clutch
Simply, but effective build list
The nismo injectors are 600cc - perfect for that power range unless your going e85. Also, I lied - It's a link G4 ecu not a vipec (essential the same) that i gave to Paul - i'll ask him if interested in selling it
100,000km service wouldn't hurt either.
Crazy - Nitto/Tomei pump, cam baffels, 8-9L race pan, race pan baffles/gates, oil restrictors turbo/head, catch can, oil cooler
moderate - billet gear replacement, sump baffels, catch-can, oil cooler, 1L overfill
basic - n1 pump, sump baffels, 1L overfill
cheers for the info mate, will send you a pm regarding parts etc..
Hahaha the only way to bed in a tyre is skids...................................................... Trust me.......................................................... :ph34r:
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
