http://www.skylinesaustralia.com/forums/topic/414822-r33-gtr-series-2/
god damn i want this!!
mad price!
Rb28, -5 turbos (probs change that), seems like a heaps genuine seller, saying it has a couple dings but there getting fixed before sold.
also, found out today im not being kept on for my apprenticeship but i may get a job for the same company but maintaining the locos that ive built for the past year, better hourly rate, and rolling roster between day and arvo shift with 4 10 hour days with the option to work any friday. a bit keen...
yeah ill find out hopefully this week or early next if i get the job as the email and everything has been sent.
dont think im gunna worry about the mines, the casual blokes at my work are on 40 bucks an hour and thats standard for newy, when you think about the distance and then having to rent somewhere in singleton ill either be living rough or saving less money then working in newy and coming home to emma every night.
plus i doubt id get in a mine cause i dont have family in there :S
http://www.skylinesa...3-gtr-series-2/
mad price!
Saw that. good price....but way down on power for -5's...but it wasn't exactly seeing much boost. Also, don't know where you got the rb28 info from.
.8 sump with baffles??
that not 2.8??
yeah i thought that about boost, would expect 280 atleast
nope just an extended sump. Mine's still a 26 and holds 9L (11L if there's oil in the cooler)
rb26's can suffer from oil starvation. With a combination big G corners, high rpm's and a poor head oil drainage design, the result is that the stock pump can essential empty the sump and thus suck air = no oil for bearings = spun bearing. After market pumps can flow more then 25% higher then stock, so the problem is amplified. The larger sump capacity pretty much eliminates the lack of oil problem and the baffels keep the oil around the pick-up during high-g corners. n1 engines came stock with a higher oil capacity, so nissan was probarly aware of the problem from there racing experince.
ahh i see, fair enough then :P
whats the advantage of a bigger sump??
hey joel hows WA? good to see your still lurking newy :D:D:D
i still check in from time to time :yes: . I'm bored at work and the WA section is dead.
WA's going well. Still haven't found a house yet though...and I'm really missing my tools (their in storage). Hopefully i'll have one by the end of the year and can start to settle in then.
ah right, where are you now then??
id imagine everything to be expensive as!
Work's got me a place in the middle of the city for a few months - it was part of a relocation package. Trouble is, i'm still working up in Port hedland, so i'm never actually in perth to be able to look for houses.
Yeah it's probably about 20%-30% more then newcastle for just about everything. But good city, very social.
I went 4wd on the weekend with a few mates, the old ferroza held up well conwsidering it's completely stock:
wow crazy!!!
newcastle is expensive enough!! cant beleive people buy investment properties in the illawarra compared to a lot of other places in the country!
jesus dude!!!
didnt know the old girl had that in her!!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
