So Martin where is this track? Can I bring big bird for a run onit? Ha
Aw man if I saw this post in time yeah you could have run.
Had a good and bad day with the car though
Was getting used to driving it then played with tyre pressures and got that sorted then dad had a drive and I jumped in straight after and was having a real go at it when I noticed smoke from under the bonnet then lots of lames from oil fire
Stupid bonnet clips meant we took about 30 seconds not 5 to get bonnet undone and put fire out
Burnt some wiring and coil lead and overflow bottle as well as the bonnet itself.
All because of the stupid plastic line for the oil pressure gauge which got hot and melted spraying oil everywhere
Still can all be fixed, at least it happened on a Test day and not the first event.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
