thought it might be worth a mention, got some walkie talkies from supercheap the other day that have a 7km range, if anyone else is keen to get a set they are on sale at autobarn for $89.
only round the house, they seem pretty good.
pretty keen to test them on the road.
can probably leave one at jarrads house and see if there is any problem transmitting to there from mine haha..
I do want! No gate tho, too lazy to unplumb it lol
So ill have to call you or get details for the Sunday man!
Picked up the car this arvo and asked the guy if you can enter on the day and he said yeah but costs an extra $10 and if no spots are available then no luck.
If you want you can pre enter and sort all the paperwork out on the day
If you want to know more ring John Collins on 49 611 600 as he knows all
Just incase no one knows yet. Me ant and a few others are going to putty road north side on Sunday to scout for our next big cruise. Let us know in here or by pm if your keen to make sure you get the details (hasn't been arranged yet)
Tim is interested too.....
Ill be there if my nugget is home, just gotta get down and get it tomorrow...
PICS OF HARNESS's!!!!!!
FYP
I have 2 in the car now ill snap some pics at lunch, i will have to feed them into the seat as i have the shoulders straps sitting on the back seat and the waist ones hidden under the seat, the mounting points are hte bolt for the rear seat buckle, replace the bolt with an eye bolt, Lower seat belt bolt on each side for 1 waist strap and the other can clip onto the seat rail after u unscrew a bolt to give it room then s crew it back in and its locked in.
Pics as requested.
On the pic with the seat out, the 2 plugs i have circled you can pull up (just a plastic cap) and screw eye bolts in, on the passenger side i had to use this as the seat belt buckle bolt was in so tight my woman hands (i work in IT) could not get it out, on the drivers side i replaced the buckle bolt with an eye bolt. Replaceing the bolt would be the preferd way to do it as when you sit on the back seat you get an eye bolt in the ass cheak.
Edited by T4NK
Sweet well have a bit of a crowd! Who's Tim??
So far we got
Me ant Ben mat benji Ben(xd) and Tim?
Him is Tim ---> http://www.skylinesaustralia.com/forums/topic/413072-tims-n15-sss-pulsar-with-a-twist-neo-vvl/
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
