Car: 1996 Series 2 R33 Skyline Gtst
Milage: 160,000kms
Transmission: Manual
Colour: Silver
Price: $8,000
Contact: Brendan 0488 901 277
Comments / Modifications:
The usual...standard turbo(reconditioned), fmic, boost, turbo back exhaust, Safc, pod, exedy heavy duty clutch, Splitfire coilpacks (fitted 12mths ago)... was tuned 11psi and 205rwkw.....whilst tuning pushed it to 13psi for a few runs....212rwkw. tuned at unigroup. car is surprisingly economical, get 550kms off a tank easy. been to the drags twice and ran a best of a 13.0 @ 108mph on street tread, get some slicks and you will see a 12.....
It has all the creature comforts like rhino alarm, turbo timer, hi/lo boost trigger switch, boost guage, cd player, aftermarket speakers. Air con recently re-gassed.
Serviced every 4,000kms as my company pays for service, brand new sparkies.
I have owned the car for 5 years, bought it off a fellow SAU NSW member. Car has been a daily its entire life, literally only taken to the drags once and ran it 2 times, dyno'd only for tuning. It has really has a soft life in my hands.
Currently running stock boost as needed to travel for work.
Reason for sale is just bought a new WRX
would you be happy to drive down to the VIC/NSW border if i was to buy it?
quite interested, but gotta see if the mrs is happy =]
ill be in touch
-Oj
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
