Can't drift in an auto? EH? all you need is corner/boost to get the rear spinning, drop it back, bounce it off the rev limiter and keep it there :) I can't wait to go out to the track to try some dorifto, just remember, all the people who think autos can't drive, will be even more surprised when anyone out there shows them :)
Yes you can drift in an auto, one of the initial drift members owns a jzx90 chaser and it is an auto he has the advantage of an 2-way cusco diff but still manages to show up a lot of people with long controled slides into and on the exit of corners and switch backs.
i hate driftin the v6 auto commodores (old girl has a vy). never thort of locking it in 2nd. that was 1 of my problems it would up shift as i slightly lifted the throttle. not good. stuff that iv got better things to drift anyway lol
ps wats your mums 9 sec commie- wat mods?
oh, that's just a joke, sarcasam :-)
Guys... I have to bust some major rules of Drift..
Firstly Generaly you can't drift an auto... Yes you can and sometimes even better than Manuals due to Long Gearing and no need to change out of gear and have that split second pause of wheels spin which can cause major drift problems...
Secondly most people don't drift heavy cars with long wheel bases because they have no Handling and heaps of Body Roll... True it's harder, but just takes more skill....
Thirdly, Don't drift a holden or a Ford... I agree a bit.. but hey...
No a Standard VS auto won't drift, It will single wheel spin.. lots.. into something hard...
Locked diff might help, But it's your mums car.. you'll surely break something when learning...
When I said I busted some rules.. I did... I drift a 1977 ZH fairlane 500 .. nearly 2 tonnes of car... Its big, heavy, Auto a Ford.. But has a 351 and an LSD and some how I seem to be able to hold a drift.. usually in the rain..
and the 3000 rpm Stall converter helps...
You may think I am insane ... But no one else has done it... and I challenge any one else to try hehe...
I'll post some pics of a drifting Pimp machine when I can
I like all these wankers who can't think you can drift this that and the other, only makes them more surprised when they see you drifting it :D
I think you'll find what a lot of people call drifting in a falcon or VS is just plain powersliding that any half arse can do. drifiting is an art and anyone who can master drifting can drift anything FWD open, anything you just gotta know how and find a track to do it on.
POWER SLIDING no
DRIFTING yes :thumbs up:
ok, thanks, and another thing, when i pull the handbreak when im driving along, say at 25kmph, this wierd beeping sound starts, ( like a computer beeping sound ) ... whats the deal with that... I assume its just a warning beep to tell you the handbreak is on and your traveling too fast to use it, but just askin you boys to make sure.
ah isurus oxyrinchus, ur not the only one out there drifting ZH's. My mate has a 400hp ZH too and he drift thats. its awesome.
and ppl who say u can drift a longwheelbase lol get a life.
so anyone can do powerslideS? lol wait till it rains and take a drive, i see alot of ppl spinning out. so no not everyone can powerslide :P
drifting powersliding who gives a shit its all fun
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
