Can't drift in an auto? EH? all you need is corner/boost to get the rear spinning, drop it back, bounce it off the rev limiter and keep it there :) I can't wait to go out to the track to try some dorifto, just remember, all the people who think autos can't drive, will be even more surprised when anyone out there shows them :)
Yes you can drift in an auto, one of the initial drift members owns a jzx90 chaser and it is an auto he has the advantage of an 2-way cusco diff but still manages to show up a lot of people with long controled slides into and on the exit of corners and switch backs.
i hate driftin the v6 auto commodores (old girl has a vy). never thort of locking it in 2nd. that was 1 of my problems it would up shift as i slightly lifted the throttle. not good. stuff that iv got better things to drift anyway lol
ps wats your mums 9 sec commie- wat mods?
oh, that's just a joke, sarcasam :-)
Guys... I have to bust some major rules of Drift..
Firstly Generaly you can't drift an auto... Yes you can and sometimes even better than Manuals due to Long Gearing and no need to change out of gear and have that split second pause of wheels spin which can cause major drift problems...
Secondly most people don't drift heavy cars with long wheel bases because they have no Handling and heaps of Body Roll... True it's harder, but just takes more skill....
Thirdly, Don't drift a holden or a Ford... I agree a bit.. but hey...
No a Standard VS auto won't drift, It will single wheel spin.. lots.. into something hard...
Locked diff might help, But it's your mums car.. you'll surely break something when learning...
When I said I busted some rules.. I did... I drift a 1977 ZH fairlane 500 .. nearly 2 tonnes of car... Its big, heavy, Auto a Ford.. But has a 351 and an LSD and some how I seem to be able to hold a drift.. usually in the rain..
and the 3000 rpm Stall converter helps...
You may think I am insane ... But no one else has done it... and I challenge any one else to try hehe...
I'll post some pics of a drifting Pimp machine when I can
I like all these wankers who can't think you can drift this that and the other, only makes them more surprised when they see you drifting it :D
I think you'll find what a lot of people call drifting in a falcon or VS is just plain powersliding that any half arse can do. drifiting is an art and anyone who can master drifting can drift anything FWD open, anything you just gotta know how and find a track to do it on.
POWER SLIDING no
DRIFTING yes :thumbs up:
ok, thanks, and another thing, when i pull the handbreak when im driving along, say at 25kmph, this wierd beeping sound starts, ( like a computer beeping sound ) ... whats the deal with that... I assume its just a warning beep to tell you the handbreak is on and your traveling too fast to use it, but just askin you boys to make sure.
ah isurus oxyrinchus, ur not the only one out there drifting ZH's. My mate has a 400hp ZH too and he drift thats. its awesome.
and ppl who say u can drift a longwheelbase lol get a life.
so anyone can do powerslideS? lol wait till it rains and take a drive, i see alot of ppl spinning out. so no not everyone can powerslide :P
drifting powersliding who gives a shit its all fun
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
